Eastern Members CT, DE, NH, NJ, NY, MA, ME, MD, PA, RI, VT, VA, WV
Finally done...
Old 04-28-2010, 11:23 PM
Nautilus's Avatar
Default Finally done...
After lots of stupid little problems (waiting on parts, broken wheel stud, F*cked up caliper....) I got it on the dyno.
KB 2.2 18lbs
Old 04-28-2010, 11:30 PM
SSINNER's Avatar
Nice ride. What did it lay down??
Old 04-29-2010, 12:51 AM
CamaroRacing12's Avatar
yea yea yea yea timmmy tellll uss!!!
so when are you and Lou gonna line them up at NED?
Old 04-29-2010, 01:12 AM
itsslow98's Avatar
KB 2.2 18lbs
Thats really all you say no numbers lol
Old 04-29-2010, 05:07 AM
Nautilus's Avatar
If you watch the video it's in the headline... 586/522 sae, 602/536 uncorrected
Old 04-29-2010, 05:09 AM
Nautilus's Avatar
I'm staying at his house this weekend to help Derek with the Foxbody.... something tells me Lou wont want to wait for NED. lol
Old 04-29-2010, 08:09 AM
Nautilus's Avatar
This is the before and after... went from the Ported blower @ 15lbs to the KB 2.2 @ 18lbs, all else is basically the same.
Old 04-29-2010, 08:10 AM
Krazy98Z28's Avatar
Is derek building a 275 car?
Old 04-29-2010, 08:21 AM
Nautilus's Avatar
No, a street car... although I'm sure by the end of the year it will have a cage in it, but as of right now there are no plans to go to the track other than to get kicked out.
Is the 275 class running 1/8th or 1/4?
Old 04-29-2010, 08:42 AM
Krazy98Z28's Avatar
1/8th
I heard his car will be on a 275
Old 04-29-2010, 08:43 AM
Nautilus's Avatar
1/8th
I dont think he'll want to set it up for the 1/8th. If anything he may catch a couple of the 9.50 classes later in the year.
Old 04-29-2010, 08:56 AM
slayer_taunu's Avatar
looks good timmy2!
Old 04-29-2010, 09:26 AM
i havent seen the mota's foxbody in awhile i should ask my dad to ask big lou about it. is it still the same orange fox? they r just taking the cage out and making it a street car or is that car long gone and this is a new one? werent they building a 1st gen camaro awhile back too? oh and btw i want there new black trailer!
Old 04-29-2010, 09:38 AM
Nautilus's Avatar
Different car completely, this is Lou's old notch back. The orange car is still sitting on the trailer.
Old 04-29-2010, 09:57 AM
Administrator
unit213's Avatar
Nice Tim! You finally pulled the trigger. Now you can stop bugging me about buying my blower.
When you get bored with it, turn up the boost. I'm at 23psi and it's making 630rwhp/600rwtq (corrected). It feels like a completely different car in comparison to when I was running 19psi. The extra 80ft-lbs really helps.
Old 04-29-2010, 10:21 AM
Nautilus's Avatar
2.76 upper with 4lb lower? What are you running for fuel?
Old 04-29-2010, 12:51 PM
Administrator
unit213's Avatar
Yep...2.76 upper with a 4lb lower. I run a mix of 110 and 93. Both are available near me
at at the pump (Sunoco). It's not a great idea to mix unleaded and leaded, but it works well.
The leaded gas is supposed to tear up the cats. So far so good though. I'm going to remove
my cats anyway.
Old 04-29-2010, 03:46 PM
98hardtopSS's Avatar
Nice timmy, very nice
Old 04-29-2010, 07:32 PM
Administrator
unit213's Avatar
How are you making 18psi Tim? Headers? A 2.93 upper will make 17psi and a 2.76 upper will make...or should make...19psi. BTW, the dyno vid sounds badass.
Old 04-30-2010, 05:44 AM
Nautilus's Avatar
2.93 upper, stock manifolds, no cats. I was expecting 17-17.5 but pull after pull it running between 18-18.5.
Next willl probably be to add a lower + Torco, since I don't have anything over 93 at the pump locally. I also have a 2.76 ring on my old blower so I may start turning it up a little later this summer but I'm going to need a clutch first. The stock clutch seems to be holding up right now just screwing around on the street but that will change I'm sure when it goes down the track.
