4l60e no first gear
Old 04-29-2010, 01:46 AM
blkgagt94's Avatar
Default 4l60e no first gear
so i got this tranny with my motor the guy i bought it from said it got a 2500 stall it stalls but when i shift from 1 to 2 u dnt feel anything but if u shift from 2 to drive it does is it cause the stall is makin it skip first? or can it b this stupit 2 gear start button i have in my 96 camaro i did the v8 swap so i dk if it effects tranny thankx
Old 04-29-2010, 08:54 AM
LS1Tech Sponsor
performabuilt's Avatar
I am assumig you have no 1st or 4th, only manaual 2-3 if this is correct you have and electrical issue with the car, Scan for codes and check fuses.
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 04-30-2010, 11:36 AM
blkgagt94's Avatar
no 1st or o/d
Old 04-30-2010, 12:48 PM
72blownvert's Avatar
Sounds like the trans is going 1st to 3rd with no 2nd or 4th. Which if that is the case you have a busted or stripped sunshell.
Old 04-30-2010, 06:26 PM
blkgagt94's Avatar
gos from 2nd to 3rd
Old 04-30-2010, 06:33 PM
98 4X4 burban's Avatar
as posted above it sounds like an electrical issue. scan for codes and dont drive it till it is fixed ( belive me i know ) or you will burn it up
Old 04-30-2010, 09:00 PM
blkgagt94's Avatar
probley is all i do is drive it to move aroudn shop i dnt drive it everday as my car untill its fixed gittin it lookd at tomar hopefully
Old 05-01-2010, 01:22 PM
So what you are saying is the trans is taking off in 2nd shifts to 3rd and has no 4th.
Old 05-01-2010, 04:36 PM
blkgagt94's Avatar
starts in 2nd shifts to 3rd an no overdrive dwn shifts from 3rd to 2nd an nothing dwn to 1st acts like its still in 2nd
Quick Reply: 4l60e no first gear
