Unplugged plug question
Old 04-29-2010, 11:16 AM
JohnnyBz28's Avatar
Default Unplugged plug question
Does anyone have any idea as to what this plug is for?
My abs and traction control seem to be working just fine and I don't have the ABS INOP light on.
Old 04-29-2010, 12:45 PM
penningta's Avatar
Im not for sure but it almost looks like an evap system plug in. Could be wrong. But it has to go somewhere. Also look and see if the abs light is on with the key on engine off. Your abs light could be burnt out.
Old 04-29-2010, 01:01 PM
JohnnyBz28's Avatar
I've seen the ABS light on before so I know it's not burnt out.
Old 04-29-2010, 07:08 PM
Red98Devil's Avatar
It looks like a two wire 3 channel ABS only connector (sensor mounted on top of the rearend housing). Was the rear axle swapped? I question the axle swap, because the pic shows a TCS/ABS wheel sensor harness running down the axle tube to the driver's side axle end...
Old 04-29-2010, 09:23 PM
JohnnyBz28's Avatar
It's got traction control and ABS. It's a 2002 car, maybe it's just due to GM laziness lol
