01 z28 convertible ?
the body is in good shape not perfect
the motor is great and pull's very good
a small dealer want's 8105.75 out the door ?
is it a good deal and it has 97k
the top is also very good no leaks
bone stock everything
That doesn't sound bad if the title is clear AND does everything work, like the a/c, power windows, etc...?? Does it need brakes or tires? Is there any maintenance history? How do the fluids look? Can you do repairs or maintenance yourself? If not, and some of these issues exist, you could end up with a close to 100,000 mile car with over $10,000 invested. That still would be OK if you planned on keeping the car for many years because it would then be in fine shape for yourself. However if you had to turn around and sell the car in 6 months you may take a beating financially, lucky to get your original $8,000 back. Check it out carefully. Good luck!
yes i can do the repairs myself and it would be my first ls car too!
