Wiring ID
Some wires can some cannot. You need to find a wiring diagram or trace out each individual wire. Some of the wires are 12v hots (PINK) coming from your fuse box to power your PCM, ing., fuel inj., ect. I think one is your starter wire.
But some can be done away with, but not many.
depends if you're going to completely rewire the car.
the purple wire is your starter wire.
fan relays, IGN wires, some sensors run through those connectors
