Weld in fill plug location for moser 9"
Old 05-01-2010, 08:37 AM
00ls6camaro's Avatar
Default Weld in fill plug location for moser 9"
Can i get confirmation and pic of moser weld in fill plug location.moser said it goes on the top of the hump for ring gear.i have seen where member had problems with it hitting the gas tank.thanks for your input.
Old 05-01-2010, 09:02 AM
LS1-IROC's Avatar
I welded one in on the back cover, next to the ring gear hump. Putting it up top makes it impossible to use as a level indicator.
Old 05-01-2010, 11:03 AM
that's what i was thinking.i would assume that it is installed just above the center of back.will anything be in the way such as phb or swb.
Old 05-01-2010, 11:36 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Keep in mind this is for the optional fill plug. The standard no charge fill plug that comes with a Moser rear is located on the driver side of the center section. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 05-01-2010, 01:59 PM
yes,i have strange center section which has it in the same location.with ta bracket it looks like it would be a pia to get to.anybody have pics of there drain and fill plugs.thanks
Old 05-01-2010, 02:11 PM
getusumws6's Avatar
moser rear fill plug. hope this helps. drains are obviously on the bottom.
Old 05-01-2010, 02:28 PM
thanks,that is what i was looking for.
Quick Reply: Weld in fill plug location for moser 9"
