Difference between LS1 and LT1 4L60
Old 05-01-2010, 07:06 PM
ReggieWarrenJr's Avatar
Default Difference between LS1 and LT1 4L60
i not sure what the differences are between them, my tranny just went out in my Lt1 camaro and i have access to a LS1 4l60 tranny out of 98 camaro, are they enterchangable?
Old 05-02-2010, 08:25 AM
98 4X4 burban's Avatar
the input shaft and the converter are different.
i also think the bell housing might be deeper on the ls1 but i am not sure maybe someone can confirm that.
Old 05-02-2010, 12:44 PM
lbdz28's Avatar
Unfortunely I think I am getting to learn the difference. I have an LS engine and trans and ordered an LS converter from PI. Looking down the center of the converter I see two splined sections and below the second splined section is a reduced diameter smooth section. I am thinking the LS converter bore should end at the second splined section as the input shaft is splined to the end. Assume the input shaft on an LT has a small smooth section on the end. Also taking measurements the input shaft on the trans is 5 5/8" to the pump and the converter is 5" to the bottom of the second splined section. Does this sound right?
Old 05-02-2010, 01:14 PM
ls1ya's Avatar
it can be made to work but not entire just bolt up interchangeable.
Old 05-03-2010, 05:53 PM
LS1Tech Sponsor
performabuilt2's Avatar
the convereter and the pump and the input shafts are different, the lt1 4l60e has a smalleer stator than the ls 4l60e
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old 05-08-2010, 09:55 AM
1976CamaroGuy's Avatar
Can someone post pictures of the different input shafts? Or at least the correct one for the LS1 4L60e?
I have a 1999 late 4L60e from a 1999 Astrovan 4.3 (I think) and I was wanting to put it behind a 2004 vortec. I need to make sure this combo will work as is or if I need to do some adapting.
Old 05-08-2010, 10:22 AM
well craps, I'm going to have to do some adapting to make mine work I think. I've attached a picture of mine.
It is adaptable isn't it or do I have to start over with another tranny?
Attached Thumbnails Difference between LS1 and LT1 4L60-dscf3780.jpg   Difference between LS1 and LT1 4L60-dscf3782.jpg
Quick Reply: Difference between LS1 and LT1 4L60
