Burnt DRL pigtail
Old 05-02-2010, 07:59 AM
Kwik6Speed's Avatar
Default Burnt DRL pigtail
anyone know what may have caused my DRL and turn signal bulb to blow. Not that this part of it is wierd, but the socket is all brown and crispy, obviously she got a little hot! what gives here?
Old 05-02-2010, 09:31 AM
Darker Shadow's Avatar
Personal opinion is because the bulb is on as long as the car is. Incandencent bulbs aren't know for being cool, unlike LEDs. Both of my DRL/Turn sockets were like that while I was blowing them. I ended up getting new ones (with longer pigtails) at Autozone, and new bulbs. Haven't had a problem since but I don't believe I've changed them that long ago.
Old 05-02-2010, 12:00 PM
sjsingle1's Avatar
changed out both of mine.......1 of then even melted the housing
Old 05-02-2010, 12:02 PM
SScam68's Avatar
Do you remember the P/N?
Old 05-02-2010, 03:22 PM
LS6427's Avatar
Change both sockets for less than $20.00. Don't buy them at the dealership.
Read this thread, page 2 also:
https://ls1tech.com/forums/general-m...blinker+socket
Old 05-02-2010, 03:29 PM
Breathing Fire's Avatar
They are cheep to buy at autozone or checker/kragen. I always have extras. As soon as I see one starting to cook I replace it. Same ones as in the link above. I have yet to have a replacement melt on me. Really easy to do and you can leave some extra wire on there so you can pull them out farther next time you change a bulb.
Old 05-02-2010, 06:27 PM
Kwik6Speed's Avatar
thanks for the "words of wisdom" guys. I just found it strange that the socket burnt up, guess it's not so wierd. My Dodge just did the same thing with a fog light as well.
Old 05-02-2010, 06:37 PM
LS6427's Avatar
Its another one of GM's horrible, idiot designs. If the socket screwed into place "from the top, facing down inside", then the sockets would never get wet and never burn out. This design has any moisture pooling at the bottom of the blinker/drl housing, which sits in the socket and burns it out.
But it also very well may be EXACTLY what GM wanted to happen, so they can sell new sockets.
Old 05-04-2010, 12:32 PM
Pitbull329's Avatar
I disabled my DRLs. The sockets should last me 2 or 3x as long this time around.
Quick Reply: Burnt DRL pigtail
