Vehicles Wanted - WTB M6 F-body CASH
Silver408
05-02-2010, 10:16 PM
I am in the market for a F-body. I am looking for a fully built car with built tranny, rear end, and motor. H/C/I cars, big cube cars, and of course forced induction cars.....
I have 15K cash and would like to see whats out there.
Brettz28
05-04-2010, 11:42 AM
http://www.ls1tech.com/forums/vehicle-classifieds/1229596-2001-camaro-z28-tx.html#post12768804
Car's in Waco, tx and was recently inspected, good til 04/11
Silver408
05-06-2010, 12:30 PM
Do you have anymore pics? Can you send pics, videos, anything else to matthew8.white@yahoo.com.
I will be in Houston 2 weeks during the month of june will you be able to get the car to houston?
Thanks,
bmnicolosi
05-15-2010, 02:38 PM
I have my 99 z28 for sale. check out my craigslist add, if still interested let me know and I can get many more details on car. http://neworleans.craigslist.org/cto/1740956627.html
8 ur svt
05-30-2010, 12:54 PM
Block: Ls7 - dynoed - 558 hp to the wheels all motor
motor only has 366 miles on it
prothane motor mounts
arp main stud kit
heads : Et performance ls7 heads / w/ cometic head gaskets & arp 12 point head stud kit
cam : Custom ground cam - 256/264 .643/.646 intake 110 lobe separation 112
pushrods: Custom length hardened pushrods
lifters: Comp cams r-series roller lifters
rocker arms: Jesel shaft mount rockers
pistons: Diamond custom pistons
crankshaft: Callies dragon slayer crank & arp crank bolt
rods: Manley “billet” rods
cooling : Meziere electric water pump
manual fan switch two levels high and lo
induction: Ls - 7 intake manifold, nick williams 90 mm throttle body , ls7 mass air flow sensor, custom air intake routed to front bumper, throttle body bypass, and custom ram air for radiator cooling.
Fuel injectors: Bosch 52lb mini injectors
fuel pump: Racetronix
fuel rails: Ls7 fuel rails
ignition: Msd coil packs, msd spark plug wires, ngk- r series spark plugs
ati performace dampener
slp - double roller timing chain
ls6 - oil pump
exhaust system : Kooks 1-7/8” race headers w/ fel -pro race gaskets
magnaflow cat-back exhaust
dual qtp - electric cutouts coming straight off the
headers at the front of the y-pipe
transmission : 6-speed custom built with carbon fiber synchros steel shift
fork. Pro-5.0 shifter prothane transmission mounts
clutch: Exedy dual clutch kit with lightened flywheel
also installed mccloud slave cylinder
driveshaft: Dennys steel nitrous driveshaft
front suspension: Bmr tubular k-member and a-arms
qa-1 front struts and shocks adjustable
rear suspension: Bmr adjustable lower control arms
spohn shortened torque arm w/ driveshaft safety loop
bmr - adjustable panhard bar
qa-1 fully adjustable shocks
bmr springs
rear end: Moser 12 bolt w / abs sensor upgrade and 33 - spline upgrade
3:73 to 1 gears
brakes : Baer eradispeed cross - drilled and slotted rotors front and back, and hawk pads
wheels : Z06 motorsport chrome w/ rivets 18 x 9.5 - front
z06 motorsport chrome w/ rivets 18 x 10.5 - back
front tires : Bfg g force ta/kd 285/30/18
rear tires : Bfg g force drag radial 295/35/18
interior :camaro “ss” front floor mats
power door locks , power windows , cruise control , abs ,
defrost, air conditioning
wolfe racecraft 6-point 4130 roll bar w/swing out option on both doors. Powder-coated black
stereo: Alpine in-dash dvd model # iva-d105
7” monitor in each front sun visor (2 total)
7” monitor in the back headrest of each seat (2 total)
there are a total of 5 monitors in this car. All of them play dvd movies.
Amps: 1- rockford fosgate power t1001-bd (powers subwoofers)
1- rockford fosgate power t4004 (powers highs for internal speakers)
subwoofers : 3- 12” jl audio w6 subwoofers in custom box
capacitor in back , and also an extra yellow top optima battery to power the stereo system.
Exterior: Custom mecham paerformance hood
custom corvette z06 electron blue w/ silver pearl complete paint
job - including door jams and under hood/ trunk
custom chrome ss emblems
custom chrome camaro rear panel lettering
power retractable radio antenna
rolled back fender wells to allow clearance for bigger tires
slp “ss” front grill
all of these items have been professionally installed, and i have receipts to show. This car has been very well maintained, and i’m sure anyone who purchases it will be more than happy.motor only has 366 miles on it, and has never been raced. I would assume this car would run a mid - 10 second pass given the horsepower rating. But i can’t confirm that since it has never been raced. All the suspension and rear end have 3,500 miles on it. This car is basically a brand new car.
99LS6SS
06-01-2010, 01:52 PM
I have a 99 SS i'm tryin to sell cheap and fast. PM my if you're interested, Located in southwest missouri
racejunky02
06-22-2010, 10:51 AM
I am asking a little more but I am sure we could work something out.
http://www.ls1tech.com/forums/vehicle-classifieds/1293643-viper-blue-camaro-s472-turbo-custom-build.html
