tko600 to a ls1 in 69 camaro
hey i was told i need to do the elec. speed-o to the tko600 for my wiring harness how would i do this i have just been usin the mech speed-o with my 454. if anyone could give me some info on this an a link are part #'s are pics i would be greatfully.
jason
jason
I am using a Chevy speedo cable with the TKO in my LS2 Datsun. My TKO has both electric and mechanical speedo hook ups, so don't see why you can't use the mechanical for your dash speedo and route the VSS to the PCM.
so how did u hook all this up if u dont care to share it with me lol am gettin my harness modif. in 2 weeks an need to know.
thanks jason
Try
http://www.dakotadigital.com/index.c...rod/prd109.htm
Item SEN-01-4160
If your TKO still has the ford output, call DD. They have adapter cables for space limited applications. They have old stock cables that will adapt the TKO ford ouptput with a 6" cable to the GM sender. You gotta ask for it as it's an old item they dont list any more. Then take your mechanical speedo off that.
Item SEN-01-4160
so what all did u have to buy for it to work just the autometer gauge? like for jegs.? an i know the tko haves a electric speedo somewere on it so there is a vss built in to the tko tranny?
thanks jason
thanks jason
They are very adjustable and work very good. I was impressed with how easy they are to calibrate. Mine was showing only 10 mph at an actual 70 mph. So I wasn't sure if I would ever get there. It doesn't have any problem. It will count the pulses in 2 miles and calibrate itself.
