Tranny leak...coming from where??
I had a tranny rebuild from a local transmission shop specializing in the 4L60 trans. Well I seem to have a leak, but not sure where its coming from. I took it back to the guy and he tighten'd up the pan bolts, but still leaks. Transmission lines maybe? I seen a little smoke coming from underneath the car the other day after starting it up and driving it down the block. Then parked it, looked underneath and trans. fluid leaking down and off the O2 sensor wire (trying to give an idea where its leaking). Any info would greatly be appreciated!
