TA diff cover torque specs
Old 05-04-2010, 01:57 PM
ktraver97ss's Avatar
Default TA diff cover torque specs
Does anyone know the proper torque to tighten the bolts that apply pressure to bearing caps? It is on a 97 SS with a 10bolt.
Old 05-04-2010, 02:13 PM
fleetmgr's Avatar
deleted
Old 05-04-2010, 02:37 PM
deleted??
Old 05-04-2010, 02:58 PM
fleetmgr's Avatar
deleted??
Yeah, deleted. I misread the question and posted the bearing cap torque.
Old 05-04-2010, 03:03 PM
Damn, Im having no luck finding this through searches or google.
Old 05-04-2010, 03:16 PM
1lejohn's Avatar
Hand tighten themdown first then torque them to 5-10 foot lbs. NO MORE then that. Then lock down the nut again 5-10 foot lbs. The cover bolts should be 25 foot lbs.
Old 05-04-2010, 03:24 PM
01 ss vert's Avatar
I think it's something like 10 INCH POUNDS. I know I had to borrow a small torque wrench b/c it was so low, my torque wrench wouldn't read that low.
It's in the directions....do you not still have them?
If not, I can try and look for you at home (at work now).
01 ss vert's Avatar
Now that I think about it, I think it's 5 FOOT POUNDS, sorry. Almost positive, b/c that converts to 60 in lbs and I remember that # for some odd reason. I did this just 2 months ago....
Old 05-04-2010, 04:17 PM
Thanks, got it from larry at Speedinc too, he said 5ftlbs. I bought it used for $40 so no instructions.
Old 05-05-2010, 12:18 PM
BlackBADaSS02's Avatar
I just looked at the TA performance instructions.
The cover perimeter is 25ft/lbs
The load bolts are 5ft/lbs (or 60in/lbs)
http://www.taperformance.com/PDF/Rea...structions.pdf
Quick Reply: TA diff cover torque specs
