transbrake malfunctioning
im running a 4l80 with a brake and I took the new setup to the track for the first time. First pass it worked flawlessly, every pass after that it was releasing on its own when I got close to full flash on the converter. Any ideas?
How long were you on the brake when it worked and also when it was releasing? The reason I ask is I have seen pumps get damaged from being on the brake to long. Also in a turbo or SC application I like to see a good billet flexplate to avoid pump damage. Have you talked to Carl yet? Vince
