Need advice...BBC or big LSx?
Building a 1994 Camaro Z28 roller right now. Was originally going to just throw a 427-440ci LSx in it, but now I am kind of getting the idea of putting a Big Block in it instead. What would be the pros/cons of going with a BBC instead of a LSx platform. This car is going to be pretty much a cruiser, by no means simply a drag car. And when I say cruiser, I mean some long trips (Hot Rod Power Tour etc...)
Thanks for any advice... Car will be a 6 speed car also hopefully if it can mate up to a BBC
6 & 8 Second Club
Less weight, less mods needed for a LS based engine.
Especially if it's not a trailer car, as much as I'm a BBC guy, LS makes more sense??
Yeah that is kind of what I was thinking also. Plus I am curious as to the gas differencial between say a 500+ BBC in comparison to a LSx motor. I mean either way they are both going to make a substantial amount of hp/tq.
That's what my plan was in the beginning but I've lost interest in mine. Search the drag racing section for my project to see if you're interested.
BBC won't be cheap by any means, LSx came in these cars so wiring, tuning, custom parts will be a lot less and unless you plan to go BIG an LSx will make approx. the same power.
Here's a few pro's and cons that I could think of:
BBC Pro
pretty easy to work on and make great power.
Assuming carb, then really easy to tune
Wide avaliability of parts
Allows you to clean up the engine bay (that was important to me when I swapped to a SBC)
BBC Cons
Probably going to lose your AC and Heat
Could have a significant cost in converting shocks, springs K-member, headers, fuel lines, gauges
Probably going to lose your windshield wipers
Custom headers or reworked Hooker headers
LSX Pro
Aluminum block
Low investment to power ratio (best way to write that)
Drops right in (for the most part)
Really good aftermarket
LSX Cons
EFI (I personally hate it)
Nasty looking engine bay (sorry that really bugs me)
smaller displacment (when compared to BBC)
That should give you some ideas to at least start thinking about it. I love the Gen I stuff so I swapped but an LSX probably makes the most sense.
Good luck
~Jim~
BBC Pro
BBC Cons
LSX Pro
Aluminum block
LSX Cons
Good luck
~Jim~
