Bump Stop Mod! but cable pedal is in the way.
I just did the Bump Stop Mod. I did it the Voltage method I had it stock at 4.31 and i was nervous cause I didn't feel like putting a bolt later if i went too far. I ground a bit then more and more now I am finally at 4.70. Read the maximum is 4.71 and 4.69 should be the safe number, and I searched and saw that 4.71 on SOME cars isn't throwing a code but whatevs.
My question is I just did the mod, it stops at 4.70v but the cable is only allowing it to open to 4.61v. I am not happy about it what is need to get the full advantage of the blade open until the stop comes into play. I plan on P&P my TB afterwards.
So why is the cable or pedal not allowing it to fully open, how do i fix it?
ANd does anyone know if doing this mod will hurt my chances on getting a good tune later?
http://www.installuniversity.com/ins...afapalooza.htm
Cool thanks, that sucks though i was hoping to have the MAF PP with the Throttle Body, have them match and all. God the maf is just a little freakin delicate baby...
But the Bump Stop Mod, wow, very noticable difference. That little extra you give the blade makes that much of a difference? Incredible i am very pleased with it.
