Gen 5 Camaro External Bolt-On Tech - How tough are our new camaros ?
2010 Bumblebee
05-06-2010, 05:34 AM
Just as the title says, How tough are our new camaros ?
How many miles on your car? Is it an A6 or M6? How Many drag runs have you done? What has broke ? What breaks? (nothing broken is good!)
ULTIMATEORANGESS
05-06-2010, 05:48 AM
do you mean tough? LS motors are extremely durable. it seems the first things going are halfshafts once you start making alot of power.
Camaro-Sutra
05-06-2010, 10:21 AM
Our first car had about 40 passes on it. Only thing that killed it was attempting launch control at a drag strip. Destroyed the driveshaft.
jamnut
05-06-2010, 02:13 PM
Early cars such as mine have a tsb on the m6 trans. Well over 200 drag passes about 10-15 of them in the 10's launching with over 650 rwhp before I tookout the tsb'd shaft. Not bad for any car, but if the shaft would have hung in there no telling how many years it would have hung together. I really do drive them like I stole them.
2010 Bumblebee
05-06-2010, 03:05 PM
Yes, I made a typo. What's the halfshaft? Is that the axle coming out of the rear end on both sides? @ what amount of power do they start snapping +/-?
The drive shaft or the little rubber hockey puck that replace u-joints?
That's a lot of HP. What have you done to it? What's still stock? Whats not?
jamnut
05-06-2010, 10:01 PM
it's got a stock short block, cleaned up heads, cam, full bolton's, suspension, nitrous outlet plate kit, all kinds of other stuff, just changing out the stock clutch now.
PtyMaro
05-07-2010, 10:22 AM
over 30 passes and nothing has broken yet! I'm pulling 545 rwhp and everything is stock except for the twin turbos, corsa exhaust and DR's. It's an automatic 6 speed. I daily drive the car (it's my only car). I run mid 11's all day. The car has 11k miles.
2010 Bumblebee
05-07-2010, 10:39 AM
This is the stuff I like to hear about too. :burn:
There was such a small run of that TSB it seems. I have one of the early ones too, I have about 20 passes at the track (plus getting comfortable with a manual transmission) and this car has had no issues. I have only a few mods.
danhr
05-09-2010, 03:44 PM
what's the cut off for the "early" camaro's that have the bad shaft/housing/whatever it is?
ex-SS-ve
05-15-2010, 01:53 AM
these cars are pretty solid . already at 17k miles and not one issue at all. havent been easy on it either, not one squeek or rattle from any part of the car which says a lot compared to the 4th gen rattle traps that sounded like a maracca even when new.
