I have a LS-1 carb/M.S.D intake(Edelbrock)..Can I port it to fit L-92 heads?Is the bolt pattern the same?Trying to save some dollars if I can.Thanks to all...
Its not even close to that simple. Even if you could it wouldnt work well. The runner is designed for a cathedral port. Opening up the mouth really huge all the sudden at the end will screw up the airflow badly.
