BMR Suspension
05-07-2010, 09:05 AM
BMR Fabrication
Sub Frame Connectors for the 2010 Camaro
Stiffen up the chassis and improve handling in your 2010 Camaro with Sub Frame Connectors from BMR Fabrication. Constructed of 1” x 1” x 0.120” wall rectangular tubing and 3/16” CNC laser cut and formed steel plates, these use pre-existing bolt holes on the Camaro for a truly bolt in piece. The BMR Sub Frame Connectors (SFC015) have a triangulated design that stiffens and reinforces the chassis by joining three key areas of the chassis: the front sub frames, driveshaft carrier bearing location, and the rear sub frame. Provided with grade 8 mounting hardware. Installation time is only 1 hour. Available in black hammertone or red powdercoat finishes.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrfabrication.com (http://www.bmrfabrication.com), email sales@bmrfabrication.com, or contact them at BMR Fabrication, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
http://www.bmrfabrication.com/F5/SFC015Rforum.jpg
