BMR Launches New Product - 2010 Camaro Subframe Connectors (SFC015)
LS1Tech Premium Sponsor
BMR Fabrication
Sub Frame Connectors for the 2010 Camaro
Stiffen up the chassis and improve handling in your 2010 Camaro with Sub Frame Connectors from BMR Fabrication. Constructed of 1” x 1” x 0.120” wall rectangular tubing and 3/16” CNC laser cut and formed steel plates, these use pre-existing bolt holes on the Camaro for a truly bolt in piece. The BMR Sub Frame Connectors (SFC015) have a triangulated design that stiffens and reinforces the chassis by joining three key areas of the chassis: the front sub frames, driveshaft carrier bearing location, and the rear sub frame. Provided with grade 8 mounting hardware. Installation time is only 1 hour. Available in black hammertone or red powdercoat finishes.
To preview all of BMR’s high-performance suspension parts, please visit www.bmrfabrication.com, email sales@bmrfabrication.com, or contact them at BMR Fabrication, 12581 US Highway 301 North, Thonotosassa, FL 33592, 813-986-9302, Fax: 813-986-8055.
I agree, they do look crazy. If you also purchase the Driveshaft Tunnel Brace, they tie the front subframe to the rear subframe AND they tie the left side to the ridght side. Whether you're looking for better launches or better handling, these will do the trick. They retail for $249.95.
