Are C5 and lt1 convters interchangable?
Old 05-07-2010, 01:46 PM
TheTransporter69's Avatar
Default Are C5 and lt1 convters interchangable?
hey i found this but i want to make sure it will work before i buy it. I don't know if it will
https://ls1tech.com/forums/parts-cla...rter-sale.html
Its for a c5 but on yanks site the c5 and the lt1 converters are on the same page.
any help would be appreciated thanks.
Old 05-07-2010, 04:31 PM
transsam's Avatar
Yes. They are both 298mm converters stock and are identical for interchangeability.
Old 05-07-2010, 04:55 PM
Circle-D's Avatar
Correct. You should be good to go.
Chris
Old 05-07-2010, 06:53 PM
FLT
FLT's Avatar
It will definitely fit. By looking at the pictures I would not mind seeing a front cover picture. Especially in the area where the converter clutch applies. I have seen if the clutch is damaged or slipping, the paint will change it's color or have burn marks in it. Hope this helps. BTW Yanks makes great converters. Vince
Old 05-07-2010, 07:35 PM
thanks all yeah i called yank and they said it would work so ill get more info on it thanks
