HELP!! it will only run on 4 cyl.
Old 05-07-2010, 05:22 PM
SPARE PARTS's Avatar
Exclamation HELP!! it will only run on 4 cyl.
Car was running fine, put it on the trailer to take it to the alignment shop, when i went to take it off it has been running on the odd number cylinders since, drivers side! I have ohmed out the coil pack extensions and checked for 12volts on all pink wires going to the coils all seems to be good, but they are not firing!!
Any help will be greatly apperciated.
This is a coupe foxbody turbo ls1 swap
Thanks
Old 05-07-2010, 05:40 PM
poconojoe's Avatar
Are you sure that side injectors have power?
Are you sure the ground is good going to those coil packs
Old 05-07-2010, 06:48 PM
Didnt check the injector power, but the plugs were wet. the ground ohmed out but i will go check if it is grounding.
Old 05-07-2010, 07:01 PM
rickykline's Avatar
check for spark? maybe a fuse blew for the pass side coils.
Quick Reply: HELP!! it will only run on 4 cyl.
