Question about AC Delco Cap and Rotor Kit
Does the OE AC Delco kit(part# D8103)have the four leads in the cover for the opti harness or is that part of the actual distributor???
I figured it was part of the optical sensor. The contacts are slightly corroded and I keep blasting them w/contact cleaner then the car will run but will stall out eventually. Then when I take the plug out and clean the contacts again it will run for a bit. I have done this about ten times now and its getting pretty f'n old. Now I am undecided whether I should do a Cap and Rotor Kit and clean the leads real good while I have it apart,or do I just buy a whole new Delco Optispark. Again my problem only seems to be the contacts and cash is pretty tight.
