Even MORE intake **PORN**
Old 05-08-2010, 10:13 AM
FASTFATBOY's Avatar
Default Even MORE intake ********
Pretty much final mockup, I am playing until my lifters come back from being rebuilt. Cant check piston to valve clearance without them...so I though I would share with my LTx brethren.
According to Holley I dont need the return springs on the bracket so I may cut it off. The springs on the throttle shafts are sufficient.
Still trying to find a good deal on a carb hat.
Old 05-08-2010, 10:38 AM
1badzee's Avatar
Very nice man!
Old 05-08-2010, 10:43 AM
AChotrod's Avatar
Thats HOT!!!!
Old 05-08-2010, 11:17 AM
Tapout911's Avatar
What cable bracket is that and what are you going to use for a throttle cable?
Old 05-08-2010, 11:48 AM
Leedogg's Avatar
Nice Dave!
Old 05-08-2010, 12:21 PM
FASTFATBOY's Avatar
Its a Jegs bracket, I had to mod it to clear the throttle arm for the rear blades as you can see.
I called Lokar on the cable and bought a TC 1000HT per their recommendation. Its 24 inches long, they make another one like it thats 36 inches long.
Old 05-08-2010, 01:18 PM
Tapout911's Avatar
Thanks David. AI has my intake and I was wanting to have the other stuff here when they were done with it. Ill call lokar Monday.
Old 05-08-2010, 02:11 PM
mdacton's Avatar
you do need the dual springs to pass tech, It also has a better pedal feel imo.
I would use them
Old 05-08-2010, 02:40 PM
FASTFATBOY's Avatar
I would use the throttle bracket like Mike had(MDACTON) His return springs are vertical instead of horizontal, the tab that holds them hooks with a little plate between the throttle bracket and the cable stud.
I dont know how I am gonna hook mine up yet.
Mike post a pic of your old setup.
Old 05-08-2010, 03:19 PM
Puck's Avatar
Looking good. Thats a pretty slick vacuum port setup. Wish I had the cash to go 4bbl, but I want to see how it performs with a 58mm and elbow first.
All these intake threads all of a sudden have me wanting to post my own "intake ****" thread .
Old 05-08-2010, 04:13 PM
FASTFATBOY's Avatar
Originally Posted by puck
looking good. Thats a pretty slick vacuum port setup. Wish i had the cash to go 4bbl, but i want to see how it performs with a 58mm and elbow first.
doooo eeetttt
Old 05-08-2010, 04:14 PM
FASTFATBOY's Avatar
You would crack up if you knew what that vacuum tree was off of.
Old 05-08-2010, 04:19 PM
Moderator
BizZzatch350's Avatar
Looks awesome
Old 05-08-2010, 04:31 PM
Puck's Avatar
Cant leave us hangin like that lol, what was it???
Old 05-08-2010, 04:45 PM
Icematrix69's Avatar
Nice Job! (rethinks intake setup)
Old 05-08-2010, 05:33 PM
FASTFATBOY's Avatar
Its off the bottom of the upper intake on a 5.0 mustang. LMAO!
Old 05-08-2010, 05:49 PM
CamaroRacing12's Avatar
i wonder what flows better a carb style FI or like a big *** monoblade throttle body.
btw u wanna build 2 and send me one? haha
Old 05-08-2010, 07:09 PM
Puck's Avatar
LOL best use of a Stang part since rear end swapping .
4bbl not only flows better, but has better air distribution then a LT1 style throttle body.
Most elbows are pretty big restrictions, especially the low profile ones that clear an f-body cowl - fast moving air does not like to turn that sharply.
Of course that won't matter on a 355 spinning to 6300rpm with a baby cam, but on a nasty stroker there are gains to be had.
Old 05-09-2010, 01:39 AM
i feel like no matter what the power more flow both intake and exhaust always helps.
really carb style like this intake is wayyy better then like a giant monoblade with a huge elbow? hmmm do most guys run these with no tubing running to the carb style? just open?
Old 05-09-2010, 08:52 AM
FASTFATBOY's Avatar
You use one of these if you have a streetcar and plumb it to the CAI or your MAF.
If its a racecar cut the cowl back and leave it open. If you dont require a MAF.
Read this thread
https://ls1tech.com/forums/dynamomet...-b-change.html
Quick Reply: Even MORE intake **PORN**
