Took the car to the track last night...
To be honest, I'm not real happy with the results.
Here they are...
60' 1.89
1/8 7.92
MPH 89.59
I do have to admit that I still have shitty 273's which I think is a big part of the problem. I'm going to look at changing these out soon, and see what I get. Any suggestions?
Here they are...
60' 1.89
1/8 7.92
MPH 89.59
Wouldn't that cam show much better in a 1/4. Kinda big therefore the top end is where it would shine. running the 1/8 obviously isn't doing it justice if you ask me.
I went from 2.73 to 3.42...BIG difference. You will not be able to smash the gas from a dig once you convert. Launching will take some practice! I disagree with the OP...2.73 are hurting your MPH. Try pedaling your bike from 0 with the chain on the big front sprocket using the smallest vs largest gear on the rear. That's the best analogy there is.
As you already know, those 2.73's are absolutely killing you. I'd swap to at least a set of 3.42s, but depending on your plans for the car, I'd be considering 3.73s with that big cam and the stall. What tires are you running? Suspension mods?
Again, which gears you go with is going to depend on what you plan on doing with the car.
The car should be making plenty of power, now it just needs to crank off the line.
Sorry, I do have lower control arms and relocation brackets but thats it as far a suspension..Nothing major. I was really wanting a 7.50 and I think I can get close with some gears. I knew that I needed gears when I got the cam, but I wanted to see what it would do with the 2.73's. I am currently doing some shopping for some 3.73's. As soon as I get the gears, I will post some new results.
