help removing clutch line
That groove is supposed to be there, Take two flat tip screwdrivers, and push on the outside edges of that plastic ring, there is a flat portion to do this, Push the ring in evenly on both sides, push straight in, dont try to push them towards each other, Just straight in, then it will slide in and release the metal fingers inside the hose retainer. Kinda like a fuel line only you already have the plastic piece in the clutch line.. Hope this helps.
