Transmission line locations
Old 05-08-2010, 06:48 PM
Thealien's Avatar
Default Transmission line locations
I have a 4L60 behind my 5.3 swap into my 72 Jimmy. I have searched for hours and can't find which line goes where?
Top of transmission to top of radiator? Bottom of transmission to bottom of radiator or am I backwards?
Thanks
Mark
Old 05-08-2010, 07:33 PM
lordrazo's Avatar
shouldn't matter much its flowing through the same location just different direction its using the coolant to keep cool so it will do its job im sure after i mixed mine up many times now i just use a separate cooler but "i think the bottom is feed and top is return"
Old 05-08-2010, 09:59 PM
Pocket's Avatar
It makes no difference. Both are pressurized and the rad side is just a coil submerged in coolant
Old 05-08-2010, 10:44 PM
jbsjunk's Avatar
The lower is to the cooler, upper is the return. I ran the factory cooler in the rad and a aftermarket cooler in my truck to keep things in check. As to where they go on the rad, I'm with everyone else. It shouldn't matter.
Cooler Line Locations
Old 05-09-2010, 07:53 AM
Thealien's Avatar
Thanks everyone
Quick Reply: Transmission line locations
