Advanced Engineering Tech - valve guides
garygnu
05-08-2010, 11:41 PM
dose a iron valve guide wear better or less than a bronze valve guide when using a stock ls rocker arm?
studderin
05-09-2010, 05:32 PM
this isn't really asking the right question. But iron is harder then bronze so should wear less, in genral like your asking.
Now will both last a long time, setup with the right valvetrain geomety? Or can both get destroyed really fast if setup wrong?
garygnu
05-10-2010, 07:10 PM
if the valve train geomety is set up right.
Gordon0652
05-10-2010, 08:04 PM
Reason they are Bronze is because they wear before your expensive valves like a bushing. You can replace them with iron but the coefficient of friction is higher, more wear...
one fast zo6
05-10-2010, 09:18 PM
i heard that if you have a roller tipped rocker arm then you want a bronze valve guide.
garygnu
05-10-2010, 10:40 PM
I think you mean if you have bronze guides you need roller rockers.
bww3588
05-12-2010, 04:36 PM
there is no friction really...the valves dont ride on the guide...
Gordon0652
05-12-2010, 07:24 PM
Then why do the guides wear out over time? Natural break down? lol
bww3588
05-12-2010, 08:06 PM
lack of lubrication, carbon build up inside of them taking the oil cushion away. you usually have about .002 of oil clearence in the valve guides. about the same as a bearing.
i didnt really mean there is no friction, what i ment to say was the difference in materials between bronze and steel guides is not going to create less or more friction.
quews6lime
05-12-2010, 08:19 PM
less!!!!!!!!
Mike454SS
05-13-2010, 09:31 AM
Yeah, friction is much more a function of surface finish, proper geometry and proper oiling than it is material.
They wear over time due to the geometry not being perfect, or the surface finish/stem shape/guide shape having flaws that result in metal-metal contact despite the oil film.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
