Conversions & Hybrids - oil pressure sending unit thread??
danbap
05-08-2010, 11:42 PM
does any one know what kind/size thread is the oil pressure sending unit hole is? where did you find an adapter to run a sending unit with a NPT thread?
thanks.
blk96406
05-09-2010, 12:05 AM
http://www.ls1tech.com/forums/search.php?searchid=11009878
randall 32
05-09-2010, 01:01 AM
http://www.speedwaymotors.com/LS-Series-Oil-Pressure-Sender-Adapter,20928.html with a ls6 intake i also had to use a 1/8 npt 45* to clear with the auto meter electric sending unit.
bczee
05-09-2010, 02:38 AM
If you want a cheap adapter, use the LS1 sender, break off the black plastic part.. gut it down to the metal threaded part. Drill and tap it to the correct 1/8" NPT Threads (or ?).. Cost = nothing !
danbap
05-09-2010, 08:35 AM
i tried to search for an adapter but couldn't find anything thanks guys. i was thinking about making the original one work i might have to do that, did any one find those adapter at an auto parts store?
mustang281man
05-09-2010, 08:52 AM
autometer makes an adapter, summit racing sells it. i had to use on on an ls6 syclone we just built so we could still use the syclone sending unit and stock guage.
http://www.summitracing.com/parts/ATM-2268/
2XR95Z28
05-09-2010, 02:10 PM
I used the above autometer adapter with an t fitting that converted to AN so i had a place for my pressure gauge and the other i used for my oil feed for my turbo both using AN lines...
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
