12 Second Club - 12.58 in my A4 Z28
Z28Dave
05-09-2010, 10:27 AM
went to the drag strip yesterday and had my best run@ 12.58
mods:
new tires
royal purple oil change
K&N CAI
straight pipe
and alot of practice lol
hers the slip
http://img710.imageshack.us/img710/7110/img0324f.jpg (http://img710.imageshack.us/i/img0324f.jpg/)
went against some guy in an turbo integra he claimed his v-tec wasnt kicking in and his turbo is acting up aka he cant shift or drive haha
redbird555
05-09-2010, 10:41 AM
what were u launching at? gear ratio? any suspension work? overall nice run man 106 trap id say thats about the best damn time you could have with that mph headers should net you more
blk/slvr02ss
05-09-2010, 02:37 PM
What else is done to cut 1.77 60ft times ?
1Bad97WS-6
05-09-2010, 03:52 PM
Nice must have a stall also to get 1.7 60ft my car as a best of 1.9 60ft with stock stall..
ccxxxxxxx
05-09-2010, 03:55 PM
I just dont know
RevGTO
05-09-2010, 03:56 PM
Even with killer DA, a little hard to believe with just CAI and exhaust. Converter and sticky tires, yes.
blk/slvr02ss
05-09-2010, 04:12 PM
Maybe he is doing neutral drops.
FASTEDDIE Z
05-09-2010, 06:41 PM
Does that work ? :jest:
z99ls1
05-09-2010, 07:05 PM
B.S no way
Z28Dave
05-09-2010, 08:51 PM
thats exactly what i was doing revved it up in neutral and dropped it down to 1st and then 2nd, i would also get similar results by holding the brake and bring it up to about 2000-2300 like i said it took a lot of practicing trying to get it down correctly about 26 runs but that was the best run i had so far, oh i forgot the 3.73 gears as a part of my mod
RevGTO
05-09-2010, 09:54 PM
i would also get similar results by holding the brake and bring it up to about 2000-2300If you could brake stall it to 2000-2300 you don't have the stock converter.
1Bad97WS-6
05-09-2010, 10:13 PM
This what I was about to say...
Z28Dave
05-10-2010, 12:28 AM
well i wasnt the first owner lol but the guy i bought it from said he didnt do anything major to it
Squirts11
05-10-2010, 12:31 AM
Next time you're driving the car, floor it and watch where it flashes. That'll be a good indicator of the stall size you have. Basically, if you're able to footbrake to 2200-2300 rpms, it's an aftermarket converter.
Ls1Rook
05-10-2010, 02:13 AM
Lmao @ neutral drops
My pos stock stall starts spinning them at 1500
z99ls1
05-10-2010, 08:30 AM
You did neutral drops and your car is still moving? Your lucky you still have a trasmission that works at all. Im sure it will not go to much longer. Your car will be falling apart very soon. Have fun doing neutral drops spending thousands :drive:
KevinR
05-10-2010, 08:57 AM
Wow...
CamaroRacing12
05-10-2010, 09:58 AM
x333333
dannyz
05-10-2010, 02:31 PM
Lol... this is the best " ALL STOCK" a4 claim I have seen yet.
Some day someone's gonna crack an 11.99!
work in progress
05-10-2010, 04:39 PM
so, are the new tires slicks or drag radials? I have a PT 4000 and it will only brake stall to 2500 =/- with sticky tires.
KevinR
05-10-2010, 06:01 PM
Looking at the time slip I am starting to think that you may be the one on the left. I'm not trying to talk trash, but comparing the reaction times the one on the left looks like a "first-timer" run. Plus, the 60' on the left seems like a "first-timer" run. The overall time on the left looks more feasable with your mods as well. Maybe I'm reading into it too much but do you have it mixed up?
Z28Dave
05-10-2010, 10:33 PM
no its the one on the right, and the car isnt stock as for some to say, earlier that day i was running low 13's and the weekend before that they were in the mid 13's but practice on reaction time from the tree and learning how the motor reacts after i hit the accelerator and again i wasnt sure on what the previous owner did to the motor/tranny exactly he wasnt able to find all the receipts but as far as i look in them it was no more than an engine rebuild and as everyone would say a 22-2300 stall, still pretty new on the LS motor so anything been modified i cant spot with the naked eye, been stuck on Nissans for some time but i'll ask call him and ask what else he did but from what i've seen thats the tomato
Ellsworth
05-10-2010, 10:38 PM
maybe they threw in a baby cam and converter when they rebuilt the motor?
MikeWS6
05-23-2010, 09:02 PM
B.S no way
this x10
'02TA
05-24-2010, 04:03 PM
I used to be able to foot brake my car up to about 1900-2000 rpm with the stock stall on nittos...
Calling B.S. on the E.T. though cause it takes more then an oil change and a muffler delete to get mid 12's in an auto.
'02TA
05-24-2010, 04:06 PM
Something wrong there...
pat-ls101
05-27-2010, 07:18 PM
callin' BS here.... with the time your claiming, a 106 mph trap time is not very believable....
1998Z28LOADED
05-28-2010, 12:18 PM
thats exactly what i was doing revved it up in neutral and dropped it down to 1st and then 2nd....
:hal:
Ive always wanted to use that smiley...
Mike Morris
05-29-2010, 04:27 PM
OMG this is major BS
birdmaro
05-29-2010, 10:12 PM
it has 3.73s as well?
i ran a 12.77 in my a4 camaro 3.73 intake exhaust no tune...~3800-3900 lb weight with me in it with a 1.98 60'
that mph and et doesn't add up...
the DA that day and time was 1208...which means sea level correction would put that time at 12.4
FASTEDDIE Z
05-30-2010, 08:06 AM
If this is real . More than likely your car has a stall converter (2800+) . That would be the reason for the ET and 60 ft with a low trap speed . More efficient out of the hole ,then it is at the top end . While it not considered a " major mod" to some people . It makes a "MAJOR " improvment in ET's :D
2slow2flurry-ous
05-31-2010, 10:47 AM
Sounds like complete b.s.
