Fueling & Injection - pics of fuel system setup underhood
JASON 77
05-09-2010, 05:28 PM
lookin at what everyone is doin for fuel rails and regulators. what kind of regulator r u runnin? where did u mount it.
this is for a T70 truck mani build if needed to know. thanks
tomz28
05-09-2010, 06:30 PM
hear are some for you buddy
dont mine the mess the engine was being installed, in these pics
http://i866.photobucket.com/albums/ab226/turboz28/first%20engine%20failed%20install/IMG_1276.jpg
http://i866.photobucket.com/albums/ab226/turboz28/first%20engine%20failed%20install/IMG_1274.jpg
91sbcamaro
05-10-2010, 04:03 PM
^^ Where did you locate your alternator to?
JASON 77
05-10-2010, 07:10 PM
what to do bout a return line?
brianfromhawaii
05-10-2010, 07:58 PM
some people use evap
blazin
05-10-2010, 08:07 PM
Mount the regulator on the return side of the rail.
JASON 77
05-10-2010, 08:20 PM
Any pics would b great. I have the fittings to connect to the evap line, what do u need to do at the tank to make this work? Also how is everyone running there lines from the car to fpr to rails and then the return?
blk00ss
05-10-2010, 09:48 PM
Heres mine.
http://i21.photobucket.com/albums/b265/Brittany-O/100_8114.jpg
http://i21.photobucket.com/albums/b265/Brittany-O/100_8113.jpg
tomz28
05-11-2010, 03:03 AM
i use the stock feed line as my return. the FPR sit right on top of the line. there are 2 walbro 340 pumps in the tank. the both have -6an lines that go into bulkhead fittings at the top of the sending unit. then a Y-block ties them together and -8an all the way to the back of the left fuel rail (when looking at the engine).
i hope this helps
Nasty N8
05-12-2010, 09:56 AM
Leave the EVAP line intact it is a very good vent system for your tank. Give me a call I can help you spec a system for your needs.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
