Loudmouth and cutout? Anyone have this?
Old 05-09-2010, 07:39 PM
HoLLo's Avatar
Default Loudmouth and cutout? Anyone have this?
I've searched but I cannot find exactly what I'm looking for. I love the sound of a cam chopping through a cutout, and I have Pacesetter longtubes, TSP ORY, and SLP LM2.. I want to add a cutout, but theres such little room between the merge and the muffler. I was thinking weld the cutout to the merge, or vise versa, have it welded right before the muffler, but that may not actually affect the sound too much...
Was wondering if anyone had this setup and could share some info/pics? Thanks
Old 05-09-2010, 07:42 PM
xdanny510x's Avatar
it will basically almost sound the same man to be honest.. i had a loudmouth 1 plus a cutout and couldnt really tell the difference!
Old 05-09-2010, 07:50 PM
HoLLo's Avatar
Well the 2 is much more tame.. I'm just wanting pics right now.
Old 05-10-2010, 03:24 PM
HoLLo's Avatar
anyone got pics?
Old 05-13-2010, 06:02 PM
HoLLo's Avatar
Bump.
Old 05-16-2010, 11:34 AM
HoLLo's Avatar
nobody?
Old 05-16-2010, 01:36 PM
01SS99red's Avatar
i have the setup you want to do. I put my cutout right after my tq arm brace /after the y pipe trust me it sounds way different with it open you will definetly notice a difference with it open vs closed thr lm2 muffler setup. nice choppy sound and screams i gain 9 hp also with is open vs closed. good luck and let me know how it worked out for you.
Old 05-16-2010, 08:22 PM
HoLLo's Avatar
Awesome, thanks. Do you have any pics?
Old 05-16-2010, 08:51 PM
01SS99red's Avatar
no i dont but just put it as close to your y-pipe as possible and you'll be fine . I personally run the manual one with wing nuts I dont mind it and i think it flows better then having anything in the way like the butterfly when its open you know.
Old 05-16-2010, 08:55 PM
94Z28-MSTGKLR's Avatar
BS! There is no freaking way you gained 9hp bypassing a LM1, or 2 with a cutout. I've had both of those systems and they are nothing but empty resonators. The lm2 "muffler" has a mesh screen wrapped around the inside of it that does practically nothing. I had a LM2 set up on my car with a cutout and installing the cutout was a waste of time. The only difference I noticed is with the cutout open the noise was closer to where I was sitting than with it closed...
Old 05-16-2010, 11:07 PM
SSTYCOON's Avatar
I have the TSP rumbler( same as the LM) and hav a cutout right after the the off road y pipe, I can hear the cam idle more. 225 598 112, sounds great @WOT. also I gained 8 hp and 7 lbs with the cut out installed on the dyno. I have hooker LT's
Old 05-17-2010, 09:29 AM
HoLLo's Avatar
I'm wondering if it will actually be worth having an e-cutout installed there. Sounds like it will. I just love the sound of a cam idling through the cutout.
Old 05-17-2010, 09:43 AM
01SS99red's Avatar
thank you. it is not a waste of time i also am running hooker headers and my gains are real . car also picked up 1.36mph in the 1/4. to op just do the cutout for yourself and you wont regret it.
