Homemade Air Lid Seal
Have any of you tried to make a seal/gasket for you lid using RTV? The supplied K&N rubber seal they supplied for the lid is crap and keeps coming off.
I was thinking of putting a thick beed of some of the black RTV around the edge of the lid, then just letting it dry. Do you think it will hold?
Kleeborp the Moderator™
Here's what I did (got the idea from another member on here):
Take the lid off
Clean underside of lid with denatured alcohol (anything will work, that's just what I had)
Leave air filter in place
Take wax paper, and place a sheet on top of the air filter so it covers the rubber seal (that doesn't seal worth ****)
Run a thick bead of RTV on the underside of the lid
Take lid, and put it back in place (so you'll now have a sandwich with the lid, RTV, wax paper, then filter), and lock the clips
Let sit overnight (or however long to let the RTV harden)
Take lid back off
Remove wax paper (it should be sticking to the RTV, but it shouldn't be hard to remove since it won't stick to the wax paper very well)
You now have a custom seal for your air lid.
...or just get some thin weather stripping.
Take the lid off
Take lid back off
