Stuck in the 14's are you serious
So first off I know I have a terrible y pipe merge tat will be fixed with a new 3 inch y pipe and then I am going to go again. My 60' times were between 2.500 and 2.602 which is terrible and I know that is what is really killing me. I am wondering if my MAF is a problem tho.
I read on another post someone changed out the MAF they had with a new one and a new tune and gain over a second. I am very disappointed in how I ran after reading everyone running 13's no problem and 12's wth pretty much what I have. Is it mostly driver or is it part car?
Try some different tires. Borrow some if you need to, and take it out again. That may give you a better idea of what your car will run. Your 60' needs some huge improvments.
Im more worried about the rear end all I hear is people upgrading there rear end. I am not looking to dump an s load of cash into this its a semi daily driver and not looking to convert it to a track car.
on running it to the moon what would you say shifting at is good 6k or at least over 5500?
I dont have the slips on my but the 60ft is really what is killing me. I am babying it off the start than to the mat every gear and using 4th reaching 103 to 105 trap speeds. I think I need to slip the clutch more cuz I know I am bogging it mostly from in experience and not wanting to hurt the rear end. It looks like I got some practicing to be done and the better y pipe merge and maybe a better tune to get it in line power wise. I think my1/8 mile times were around 8.9 to 9.1 in the 80-82 mph range. It is mostly me but I think part of it has to do with the car. I will no more once I get the new y pipe in and go run it again.
i just got an 02 ws6 78000miles bone stock except flowmaster catback. its an a4 with worn street tires. i didnt do a burnout babied it off the line and ruan a best of 13.6 something at 104.88 with a 2.2 or 2.1 60'. so if ur trapping 105 u should be lower then a 13.6 at least.
That mph has low 13s all over it and with your mods Id shift at like 6200. Get some Nittos if its a semi DD run them at 18psi and do a good long burn out and leave about 4k quickly slipping the clutch. That should drop your times a lot!!!
When my car was almost stock except a cat back and some old nittos it went 13.3@103 driving like that and its a LT1.
Shift at 6k, put some stickier tires on it and get the sixty down to around 2.0 and you'll be amazed at the difference. It doesn't sound like a mechanical problem.
Posting your timeslips would help alot. I mean you could be running 14.1 or 14.9 for anyone knows. Mine was running low 14s when I bought it stock. Not all Ls1 cars run low to mid 13s out of the box, very few do around here anyway.
I would love to just run a low 13 I will have to just try to get my 60ft down in hopes of gettin it there. I am trapping 105 on my best run so I think a low 13 is a good mark I would love to just break into the 12's maybe in time I will.
