T56 Wont shift into 2 4 or 6th
Old 05-10-2010, 03:49 PM
Stuka735's Avatar
Default T56 Wont shift into 2 4 or 6th
i was driving and randomly i couldnt shift into 2 4 or 6th gear only the others. its a stock tranny with on my 00 SS, mods are intake manifod/headers/cb exhaust/intake/hurst plus shifter
not sure why but i really dont have the money to fix it so hopefully it isnt totally messed up
Old 05-10-2010, 04:04 PM
99ssleeper's Avatar
check your adjustment stops on the hurst. sometimes the vibration will make the bolt loosen and walk in.
Old 05-10-2010, 04:09 PM
Stuka735's Avatar
going to check the stops on the hurst and also change slave fluid. update after
Old 05-10-2010, 04:14 PM
Mr. Trick's Avatar
I would check the stops before changing the fluid, since the problem is only with the bottom three gears.
Old 05-10-2010, 05:01 PM
Stuka735's Avatar
wow i feel like a loser the stop was all the way up on the bottom. thanks for the help!
