bigger tranny pan for lowered cars
Old 05-10-2010, 06:30 PM
z28_n_tx's Avatar
Default bigger tranny pan for lowered cars
car's lowered (prokit) is there a after market tranny pan that wont cause me to have issues with it scrapping??
or a pan that is the same as stock that has some sort of way to keep the tranny running cooler??
thanks
Old 06-01-2010, 02:55 PM
z28_n_tx's Avatar
anyone???
Old 06-01-2010, 11:16 PM
dnkynrbk's Avatar
There are not any low profile tranny pans besides the stock one.
Old 06-05-2010, 09:05 AM
mikey1107's Avatar
You could try a 4l60 truck "deep" trans pan and filter.
It only adds probably a quart of extra capacity but that's better than nothing. And you would probably have a little more ground clearance than the aftermarket deep pans.
and they are cheap!
Old 06-05-2010, 09:58 AM
meine96ws6's Avatar
Well, if your not having any issues with your current set up then your fine..
Old 06-05-2010, 11:24 AM
jsteele90's Avatar
dont get a trick flow deep pan. mine hangs LOW
Old 06-06-2010, 09:08 AM
z28_n_tx's Avatar
and they are cheap!
liink??? i might look in to it...
Old 06-06-2010, 09:13 AM
z28_n_tx's Avatar
imabout to have my tranny rebuilt so i can put my yank ss3600 and b&M COOLER 24K...car's otrherwise stock in that department now, just wanted to see what i could do to keep tranny cooler.
Old 06-07-2010, 07:07 AM
mikey1107's Avatar
This pan would be a factory pan for a pickup. Get ot from either a dealer or salvage yard. I think they are like $25 new from a dealer. Just make sure to get a matching filter and gasket kit because the fluid pickup will be lower.
You can search this forum and you should find some info on using truck deep pans.
Old 06-07-2010, 09:33 AM
mikey1107's Avatar
Don't know.... I would use a cooler for extra cooling. Not rely on the pan for that.
Old 06-07-2010, 01:38 PM
01ssreda4's Avatar
Bigger cooler>deeper pan
Old 06-07-2010, 01:44 PM
mikey1107's Avatar
Old 06-07-2010, 04:39 PM
dlk1950's Avatar
I have a bigger cooler w/fan & deeper pan. My car is not lowered and I have to be very careful of what I drive over..I may end up putting my stock pan back on.
dave
Old 06-07-2010, 07:35 PM
Moderator
jimmyblue's Avatar
I stepped back from the TCI finned super-deep pan to the
truck pan because I was collecting too much yellow paint
on the drain plug. Truck pan is not the lowest thing in the
undercarriage and if you do tag it, it's steel and can take
some abuse. '02 Silverado is a good app to reference if
you want the drain plug.
Old 06-08-2010, 05:52 PM
355TurboLT1's Avatar
Rossler offers an exclusive moroso fabbed pan. Pretty sure it holds about two extra quarts. Clearance looks good as well. And on the topic of added fluid, there is usually always a temperature reduction from this. It may not be 20 degrees(closer to 10) but this added benefit is only adding longevity.
Old 07-15-2010, 06:24 PM
z28_n_tx's Avatar
so ineed an 02 silverado truck oil pan with the filter and the gasket right?? all from the dealer ???
also will i still be able to use my dip stick to check the fluid??
Old 07-15-2010, 07:31 PM
Hardtop's Avatar
I'm running a truck pan.
Pan # 24229658
Filter #24208576
Old 07-15-2010, 08:11 PM
RapidRick's Avatar
thanks
Look at a DERALE.
I have one of their "Cooler Pans" on my Formula for 2 years now. Adds 2 qts. has drain plug. You can get it for approx $70 give or take a fin ($5)
No problems. I'd recco it to anyone.
http://www.derale.com/
part # 14104 & 14204 (new #)
do a google search on "Derale 4l60e trans pan" for best price quotes.
Attached Thumbnails bigger tranny pan for lowered cars-challenge-race-12-19-09.jpg   bigger tranny pan for lowered cars-p2170008.jpg   bigger tranny pan for lowered cars-p2170002.jpg   bigger tranny pan for lowered cars-challenge-formula-launch-5-2-09.jpg
Old 07-16-2010, 10:41 PM
z28_n_tx's Avatar
so i can i still use my dip stick or do i need a diff one??
Old 07-16-2010, 10:43 PM
z28_n_tx's Avatar
Pan # 24229658
Filter #24208576
are these chrvrolet dealer part #s...
