Removing driveshaft. . . .need help??
Old 05-10-2010, 08:17 PM
Yahelou's Avatar
Default Removing driveshaft. . . .need help??
So im droppin the motor and tranny, and im to the point where im takin out the driveshaft. now i put the car in neutral, but i did that after i uninstalled the battery and tranny lines, and the driveshaft wont spin at all. rear wheels are off the ground and hand brake is off. what am i doing wrong? do i need to put the car in park, then reconnect the battery, and then put the car in neutral? the pcm is disconnected, does that matter? thanks for the help.
Old 05-10-2010, 08:22 PM
ski23's Avatar
Should spin freely if in neutral, ebrake is off and tires are not touching ground. There will be some drag and might not be able to turn driveshaft by hand. Grab the tire and turn it till you get where you need to be
Old 05-10-2010, 10:35 PM
Yahelou's Avatar
well thats another problem. i did that and one tire spins one way, and the other tire spins the other way.
Old 05-10-2010, 11:11 PM
KrisXpc's Avatar
^^ That's suppost to happen....
It's normal
Old 05-11-2010, 08:08 AM
01ssreda4's Avatar
^^^agree'd. Stop worrying what the other tire is doing, just get the DS off
Old 05-11-2010, 08:10 AM
deelong4002's Avatar
That's posi.
It should freely spin if in nuetral and off the ground
Old 05-11-2010, 09:05 AM
Yahelou's Avatar
haha, i know thats whats supposed to happen. the problem is even when i spin the tire, the ds still isnt moving. do i need to spin both rims in the same direction to get the ds to move??
Old 05-11-2010, 12:23 PM
01ssreda4's Avatar
Like stated, you should be able to turn it in neutral, by hand. If you can't, stick a screwdriver in the DS yoke and use that as leverage.
Old 05-11-2010, 01:00 PM
Weezzer's Avatar
Originally Posted by Yahelou
...the problem is even when i spin the tire, the ds still isnt moving...
If this is the case, then your rear is gone.
Old 05-11-2010, 01:10 PM
Yahelou's Avatar
i have been doin that and still wont freakin budge
the rear was completely redone barely 4 months ago
Old 05-11-2010, 01:11 PM
Just take the torque arm off, and then you should be able to get to the top bolts on the DS
Old 05-11-2010, 01:47 PM
Yahelou's Avatar
yea thats what i was gonna do as last resort. actually might be better, since i need to detach torque arm from the tranny anyways.
Old 05-11-2010, 06:37 PM
Yahelou's Avatar
ok, so my buddy figured out. i disconnected the shift selector cable, so the car was still in park. once we changed it, the driveshaft rotated easily.
Old 05-12-2010, 08:02 AM
01ssreda4's Avatar
Old 05-12-2010, 09:33 AM
Yahelou's Avatar
yea tell me about it. haha.
Old 05-12-2010, 11:44 AM
99ssleeper's Avatar
It is possible for the DS to remain still when one wheel spins forward and one spins backward.
Old 05-12-2010, 02:37 PM
cambirdracing's Avatar
Yes, if it has an open(one wheel peel) carrier. If it is posi and it does this, then the posi is bad.
Old 05-12-2010, 04:20 PM
Yahelou's Avatar
so what ur sayin is if the car is in neutral and the tires spin and the d/s doesnt, then the posi is bad?? or does that also apply if the car is in park?
Old 05-13-2010, 10:43 AM
99ssleeper's Avatar
for whatever reason i thought one went forward and one went back when i spun my torsen with no d/s.
Old 05-13-2010, 10:09 PM
dwfronk's Avatar
Thats what mine dose and my rear end is stock as a rock and never been touched. I had to spin both tiers in the same direction to get the D/S to turn. That and i layed under my car one day playing with it when i got board after putting on my new torque arm. LOL
Quick Reply: Removing driveshaft. . . .need help??
