FINALLY got my pacesetter lt's :)
Old 05-11-2010, 11:52 AM
blackfbird98's Avatar
Default FINALLY got my pacesetter lt's :)
well they finally came and i couldnt be more happy! my only question i have is what should i do about relocating the oxygen sensors? they sent the wiring to splice it but isnt there a harness i could buy to make it just connect up instead of going through all that?
Old 05-11-2010, 12:36 PM
noxiouSS's Avatar
yes there is. Im not real big on electrical so i just paid for the plug in play extensions.
Old 05-11-2010, 12:45 PM
sscamaroburn02's Avatar
just buy the 02 extensions and be done. just plug and go
Old 05-11-2010, 01:02 PM
ok great now ive heard there are different kinds like denso and bosch and the corvette 02's so what do you guys think i should be getting or what worked best for most of you?
Old 05-11-2010, 01:04 PM
bought mine with pacesetters from TSP.
Old 05-11-2010, 01:19 PM
shaun's Avatar
i got mine from tsp also they where like 40 bucks for the set.
the wire and hardware they send with the pacesetters is crap.
Old 05-12-2010, 04:27 AM
StrokerAce03's Avatar
I used rear o2's for a Corvette; Bosch part #13111. The harnesses for them are long enough and they have different heaters in them.
Old 05-12-2010, 07:19 AM
have you had any problems with them? ive heard the boschs throw codes right away sometimes?
Old 05-12-2010, 10:35 AM
96blackta's Avatar
So you're saying those oxygen sensors are a direct fit and the wiring doesn't need to be extended?
Old 05-12-2010, 10:46 AM
conor.davis's Avatar
Yeah they are, they have longer wires so you don't need to extend them.
I am using them and they havent thrown a code.
Old 05-12-2010, 10:53 AM
udienow's Avatar
You do not need extensions if you use the bosch 13111 vette sensors. I have used these in my car for the past 10k+ miles without any problems or codes. I also have the pacesetter LT's.
Old 05-12-2010, 11:41 AM
Red Devil 99''s Avatar
I used the extensions on mine and have never had a problem.
