Patriot LS6 stage 2 heads?
Old 05-11-2010, 08:19 PM
tg580's Avatar
Default Patriot LS6 stage 2 heads?
Just bought a set of Patriot stage 2 heads. What do you guys think them?
Old 05-11-2010, 11:19 PM
garygnu's Avatar
I hear they are ok heads.you probably are looking for a cam to fit your combo.list all of your car stats and goals and a lot of helpful people will chime in. stall,gears,exhaust,car?
Old 05-11-2010, 11:35 PM
Squirts11's Avatar
They're hit or miss heads. What size valves? Chamber size?
Old 05-12-2010, 05:32 AM
tg580's Avatar
Its a 99 WS6. Custom grind 224/226 .580ish, long tube headers, ory, underdrive pulley, ls6 intake, 3200 stall, 3.73's. The head is 2.02/1.57, 64cc chambers, 300cfm@.580
Old 05-12-2010, 08:07 AM
garygnu's Avatar
sounds like a good combo,is it tuned yet?with a good suspension and DR you should have fun.
Old 05-13-2010, 08:01 PM
tg580's Avatar
I'm still putting it back together. I had the computer sent to speed inc. I'm going to try to take it there for a full dyno tune.
Old 05-13-2010, 08:18 PM
supersick99z's Avatar
Just curious what you paid for them? I picked up a set 2 weekends ago for $600 and they are sitting in my floor waiting to be put on
Old 05-13-2010, 10:53 PM
King Nothing's Avatar
wow i didn't realize they were that cheap in price
Old 05-14-2010, 09:02 AM
Yeah I got them for that price with valves no springs. I wasn't evening planning to get them and then I was like wow I can't pass that up!
Old 05-16-2010, 10:50 AM
tg580's Avatar
I paid $1295 complete.
Old 05-16-2010, 11:18 AM
peterlawl84's Avatar
Are both those prices for new or used heads though...I can see the 1295 for new heads, while the 600 for used...?
Old 05-16-2010, 04:18 PM
tg580's Avatar
The $1295 was new. I tried getting them through Patriot at first but they were 5 weeks out. They told me that they had just sold some to Jeg's so I called them and got the heads for that price.
If those are brand new at $600 without springs that is one hell of a deal. You can get Comp Cams double springs for under $400.00. I'm not sure about the titanium retainers though.
Old 05-16-2010, 06:30 PM
Yea, thats what I was thinking, the 1295 you paid isn't a bad price for the heads, I assume you got the package with springs, at least I don't think so.
I just picked up a set of used Patriot 243s and made the numbers listed in my sig. At first I was alittle dissapointed until I found out it was a load bearing dyno, so dynojets would read 8-10% higher, plus I know my wheels don't help those numbers. Just picked up a ported Fast 92, so I'll be interested to see how much that picks up.
Old 05-16-2010, 06:46 PM
tg580's Avatar
I'm in the middle of putting my mods together. I'm going with the patriot heads, LS6 intake, ported and polished throttle body, 224/226 .581 112 lsa cam, pacesetter long tube headers and no cats, SLP underdrive pulley, 3200 stall, 3.73 gears, lower control arms, panhard bar and subframe connectors. I am really hoping for 400 rwhp and torque. I guess we will see.
Old 05-16-2010, 10:26 PM
I think you should be close to those to your goal. I did Patriot 243 heads, TR 228/232 cam, LS6 intake, Kooks LT, catted-y, borla exhaust and my big *** wheels got 392/385, which is 420-430ish on a dynojet. My car only has the 3.23 gears, so your car should be alittle fast tool.
Good luck with your build, post jup the results when you get them.
Old 05-16-2010, 10:35 PM
GR8GAME's Avatar
I got 224/224 .581 cam
Patriot stg II 59cc heads
fast 92 combo
kooks +ORY through dual dual muffler
12 bolt w/3:73
ebay UD pulley
420/390 on load bearing
+17x11 boyd smoothie II's
No those times in sig are incorrect.
Old 05-17-2010, 10:06 AM
mine was shipping my 243 heads and them redoing everything on the head, they pretty much made everything on the head new
Old 05-17-2010, 08:22 PM
tg580's Avatar
fast 92 combo
12 bolt w/3:73
ebay UD pulley
So what are the correct times that you have run?
Old 05-17-2010, 08:43 PM
Sprayed 99's Avatar
times in my sig with patriot stage 2's. worked really well. i had stock valves in them too
Old 05-17-2010, 08:47 PM
tg580's Avatar
What size cam and what intake?
Quick Reply: Patriot LS6 stage 2 heads?
