Clutch Problem
Clutch Problem
My clutch does not come all the way out as far as the other pedals, unless I grab it and pull it out. When I push in the clutch in only comes back out about half way then stays there unless I pull it out. I put in more fluid and it fixed it a little, but it still gets stuck halfway sometimes. What can this be. Thanks for any help
Same issue, only at 3-4 gear shift.. Try the ranger clutch care.. If that dont work.. Bleed the hydraulics.. If that fails.. Time for a Master cylinder replacement.. Recommending a Tick Adjustable.. If that dont fix it.. Slave cylinder probably needs replacement..
Ranger clutch care link:
http://www.rangeracceleration.com/Clutch_Care.html
