help asap
Old 05-12-2010, 10:12 AM
01zb4c's Avatar
Default help asap
Ok need help asap! the car is in the way... car ran just fine we put headers and a ls6 intake on it and now we go to start it and it wont idel... unplug the maf and it will run just fine, just idels down slow... we put a different maf on same problem... i dot know what else it could be. the codes on it are all dealing with the maf... Thanks
Old 05-12-2010, 10:16 AM
eseibel67's Avatar
Check your ENG SEN fuse.
Old 05-12-2010, 10:53 AM
RARON455's Avatar
could also be a vaccuum leak, make sure that you have two hoses connected at the back of the manifold, a large one and a small one.
Old 05-12-2010, 11:14 AM
udienow's Avatar
Double check all the connectors/hoses... you probably didnt plug something in.
Old 05-12-2010, 11:27 AM
01zb4c's Avatar
the small hose in the back is pluged in and the big one is the one that goes to the brake booster right? the sensor in the back of the intake is pluged in... what else should i look for? its not a fuse cuz the car run and starts just dies when u plug in the maf...
Old 05-12-2010, 11:56 AM
02TribalsWS6's Avatar
check your O2's, are they plugged in? and are you not using rear O2's and possibly plugged your fronts into the Rear's?
Old 05-12-2010, 12:20 PM
BadA** SS's Avatar
02 sensors are in and plugged in right
Old 05-12-2010, 03:22 PM
eseibel67's Avatar
I'm not saying this is your problem, but the car will still run (like ****) with the ENG SEN fuse burnt. It supplies 12v to the MAF and the O2 heaters.
Old 05-12-2010, 03:34 PM
BadA** SS's Avatar
car is fixed now...our auto mechanics instructor put his hand over the tb and let it bogg down...let go.. put the maf back on and plugged it in and it worked so we dont know what happend...thanks for the advise though guys
Old 06-09-2010, 01:56 PM
Banned Scammer
434strokergt45r's Avatar
go over everything you unhooked backtrack you will get it
Old 06-09-2010, 02:01 PM
KevinR's Avatar
Ummm....You're a little late on this one, my friend.
