GTO Clutch
Old 05-12-2010, 12:29 PM
SppeedAddictt's Avatar
Default GTO Clutch
Has anyone installed a '05--10 Z06 clutch in an 05 gto with stock engine, does the flywheel need to be changed?
Old 05-12-2010, 06:34 PM
Glenn B's Avatar
Yes, you will need the LS7 flywheel to use the LS7 clutch
The LS7 FW and pressure plate are unique to each other.
OR- you can get an aftermarket AL or steel FW, but that will be more expensive.
The LS7 clutch is a very popular upgrade.
--Glenn
