GEAR HELP!?!?!? 2.73 to 3.73???
Old 05-13-2010, 09:50 AM
Purple94Z28's Avatar
Default GEAR HELP!?!?!? 2.73 to 3.73???
So my rear end is at a local shop to put my 3.73 gears in and he got it all put together and he says there is way to much backlash? He says i need a diff rear end or carrier to fit the gears? Also i looked something up online about a spacer that will make the gear fit in my 2.73 rear end? Im just looking for an answer? Thanks in advance for any help.
Thanks,
Nick
Old 05-13-2010, 09:55 AM
always faster's Avatar
You probably got a 2 series carriers (2.73 original).You need a gear set for a 2 series carrier or a 3 series carrier to install a 3 series carrier gear set.
Your 3.73 is for wich carrier...
Old 05-13-2010, 09:56 AM
TCS OFF's Avatar
You probably got the wrong gears for your carrier. My car has 2.73's and when i was looking at 3.73's you gotta get the right gears for your series carrier. I think yours is a series 2 and you probably got series 3 gears
Old 05-13-2010, 09:59 AM
yea thats probaly it because i got them of a kid used he had them in a ls1 camaro and decided to go with 4.10s...so if i get a 3 series carrier it will bolt right up to my rear end?
Old 05-13-2010, 10:08 AM
TCS OFF's Avatar
I'm not sure what all you have to do to make the series 3 fit in your diff, might slip right in there. If it wasnt a private sale i would say just take them back and ask for the other series ones
Old 05-13-2010, 10:26 AM
djjab57's Avatar
It would be easier to get a 3:73 for 2 series carrier, yes they do make them. but yes you could get a 3 series carrier (different rear end) and it will work
Old 05-13-2010, 10:31 AM
okay well this guy localy has a 3 series rear carrier and he wants 90 bucks for it and needs new carrier bearings? Is that bad?
Old 05-13-2010, 10:49 AM
Z28Roxy's Avatar
No.
Old 05-13-2010, 12:30 PM
RamAir95TA's Avatar
What kind of shop doesn't know what the f*** they are installing?
Old 05-13-2010, 04:12 PM
pillarpod's Avatar
^ good point
Old 05-13-2010, 05:21 PM
infinitebird's Avatar
you generally want to replace the bearings anyway when you do a gear swap if they are really old.
summit sells a kit that has everything like that.
Old 05-13-2010, 07:09 PM
gregrob's Avatar
Most shops don't take used junk to put together. Not surprising they didn't notice it lol the had them in. Id just buy a new set of gears for a 2 carrier and be done
Old 05-13-2010, 08:34 PM
MasterTomos's Avatar
+1...you need 3.73 gears for a 2 series carrier.
Quick Reply: GEAR HELP!?!?!? 2.73 to 3.73???
