Antenna questions - taking out power antenna and installing camaro unit
Old 05-13-2010, 03:14 PM
ConfusedGarage's Avatar
Default Antenna questions - taking out power antenna and installing camaro unit
First off, I appreciate any help in advance.
So, like most, my 1998 WS-6 antenna motor died, makes noise, no go. So I want to just install the non power camaro unit in its place, I like the stock look and dont want to waste $100 or do the univeral or the bitviper fat short one.
Here is where I get confused. I just figure Id order the camaro base, and mast. Well looking at gmpartsdirect.com, they have the following options for a camaro:
Antenna mast, Antenna power, Bezel, Cable, Mast
What all do I need? (My thought was Antenna mast and bezel). Why is antenna mast an option for $10, then Mast power also an option for $33? What is the cable?
I really appreciate any feedback on this!
Old 05-13-2010, 03:30 PM
mike7701's Avatar
Scroll down on that same page and view the illustration and it will show a diagram and you can click on each link to each piece to buy, I would think you would need all of it minus the cable of course.
Old 05-13-2010, 04:20 PM
99'CajunFirehawk157's Avatar
Thats exactly what I did to mine, works great too, when I cover the car just unscrew the antenna.
Old 05-13-2010, 04:40 PM
eseibel67's Avatar
If you just want a solid antenna, buy one out of a junkyard for almost free. I would think if the hole is the same size, any GM would work.
FWIW, my power antenna crapped out a couple of weeks ago. The $30 GM replacement (PN 10256439) was easy to swap, and the power antenna now works quietly.
Old 05-13-2010, 05:59 PM
98ZEMT's Avatar
I'm looking to go the other way. I have a Camaro with the crappy stock antenna and I want to go to the power unit. What do I need? The power ones are a tad harder to find.
Old 05-13-2010, 07:50 PM
eseibel67's Avatar
Obviously you would need the whole power assembly. The mounting is: the hole in the fender, plus one screw in the spare tire holder. I can send you a pic if you wish.
As far as wiring, you'll need 12v and a ground to power the antenna. You will also need a 5v signal wire to raise and lower it. I assume the stock Camaro radio will not have this feature, but maybe it does. Aftermarket HU's have a signal wire.
My guess is that this project is very doable.
Old 05-13-2010, 08:39 PM
98ZEMT's Avatar
Would anybody be interested in trading? I'd even take a busted set up and buy the new GM electric part.
Old 05-13-2010, 08:40 PM
98ZEMT's Avatar
Yeah a pic would be good. If you can.
Old 05-13-2010, 09:04 PM
eseibel67's Avatar
Pic is a bit fuzzy, but the arrow is pointing to the single mounting screw:
Old 05-13-2010, 09:08 PM
98ZEMT's Avatar
I can just use the blue wire from my head unit. The remote wire you use for an amplifier.
Old 05-15-2010, 06:14 PM
Thanks!! Perfect, I was blind and didn't see. Yes, looks like I need all except the cable. Not sure where to get that mast retainer nut, guess I'll look at that when the other pieces come in.
Old 05-16-2010, 09:29 PM
98ZEMT's Avatar
Alright guys and gals. I managed to find a power unit out of a 1994 bird. The bracket is different than the one in the picture above but I was able to bend it and drill new hole in the car bracket to make it work. Problem is the motor is great. Goes up, goes down. Minimal noise. Now, problem is the mast itself. The plastic ribbon is too short. I assume at one point or another it broke. I ordered a new one from GM parts direct. 50 damn dollars mind you. Question is, how do you install it? Do you just make the motor wind out like its making the antenna go up and put the ribbon in and let it go back down? Or do you have to take it apart? Thanks.
Old 05-17-2010, 10:07 AM
98ZEMT's Avatar
Anybody have an answer to this? I figured you Bird guys have changed these a few times.
Old 05-17-2010, 03:26 PM
eseibel67's Avatar
The method on the instruction sheet didn't work for me. I had to open the case and remove a 3" long piece of the old tooth gear.
Not a problem, though. Just break off the plastic **** that hold the motor/gear case together. After removing the broken tooth gear piece, I cleaned the inside and re-lubed with white lithium grease. Then drill new pilot holes and reassamble with teeny screws.
Attached Thumbnails Antenna questions - taking out power antenna and installing camaro unit-antenna-instructions.jpeg
Old 05-17-2010, 03:55 PM
98ZEMT's Avatar
Thanks! Should work for me.
Quick Reply: Antenna questions - taking out power antenna and installing camaro unit
