Power Window Modulator?
Super sorry if i this has already been posted, but i didn't find anything.
would anyone happen to know where the window modulator is and how i can get to it.
All i know is that i've been told its in the dash somewhere.
My driver side window does not work, and i know its not the motor, switchs, or fuses, so ive been told that in rare occasions some modulator in the dash somewhere will go out resulting in the window to not work.
please correct me if im wrong on any of this.
any suggestions would help, thanks
-adam
-adam
but if i remember correctly it was checked. Just dont remember the results
i just remember i was told after checking everything that it most likely is the modulator,
and thatll only cost me like $45 at a junk yard.
from the driver's side its about 6 inches to the right of the gas pedal. its fitted in a little pocket on the firewall. you'll have to pull the little knee bolster/ footwell closeout to pull it out, but if you are small, you may be able to see it without pulling the closeout.. i'm 6'3" and 320 lbs, and i can get to it and have it out in less than 10 minutes. its easy. not a cheap piece, but its easy.
Theres no clicking, no nothing.
