shim problem?
shim problem?
i recently bought an 02 ss and the seller said he installed a spec stage 3+ clutch. it requires alot more effort to get into gear than i know it should because ive had other fbodys. i know alot of spec clutches require the slave to be shimmed. if he didnt install the shim could that be a cause of my problem?
Just a piece of metal or any other material used to move the slave closer to the clutch for proper clearance.
