Gforce Engineering
05-13-2010, 09:44 PM
Gforce Engineering is proud to announce that our new 5th Gen Camaro axles are ready.
We have 2 versions of axles for the Camaro. 4340 and 300m.
Our axles come with a 2 year warranty.
Our 4340 axles use 4340 billet inner and outer stubs with 4340 axle bars. These axles are rated to 1000hp and feature our patent pending bolt together inner axle stubs.
Our 300m axles use 300m billet inner and 4340 billet outer stubs with 300m axle bars. These axles are rated to 1000+hp and also feature our patent pending bolt together inner axle stubs.
We incorporated a standard and large diameter axle arraignment to eliminate wheel hop. We have fine tuned this method with our very successful GTO and CTS-V axles and have used the same design approach with the Camaro axles.
Our patent pending bolt together inner stubs allow the stubs to broken down with 6 bolts so you can up-grade down the road with new products not yet release. The OEM stubs are 32 spline, we will be offering a 35 spline spool and matching stubs in the near future. With the bolt together stubs, all you would have to do to up-grade is swap out the stub ends at a fraction of the cost of all new stubs.
If you ever damage a stub, it's only about $150. to replace one.
How strong is this bolt together stub design you say? We have been selling our bolt together stubs in the GTO market for a couple years now and have never had one broken. We've never had to replace a single stub and there are a bunch of them out there in big power cars.
Here is the link to the axles in our on line store.
http://www.shop.gforce1320.com/product.sc?productId=94&categoryId=36
The 4340 axles are $1599.
The 300m axles are $1799.
The axles come standard in a nice black baked on finish to protect them from the harsh elements.
Here are some custom powder coated axles that are going on the BMR Shop car. BMR is a dealer for our products so give them a ring if you need some axles.
http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/Redaxles.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/Redaxleinnerstubs.jpg
http://i25.photobucket.com/albums/c91/nicholscl/Camaro%20-%20G8/Redaxleouterstubs.jpg
Thanks
Chris
Thanks
Chris
