Drag Racing Tech
26 or 28 ET Drag
Old 01-11-2004, 11:32 AM
vette=lack of penis
Cursed1's Avatar
Default 26 or 28 ET Drag
I am trying to get some info together. Are most guys running 28" ET drags or do you think a 26" would suffice most of the LS1 modded cars. I am talking on more of a heads and cam type car. With or without N2O. What has been your experience. Thanks, Christopher
Old 01-11-2004, 12:01 PM
EVIL's Avatar
depends on your gearing and power band.
a 26 with 3.73's will work far far better than a 28 with 3.73's. but a 26 with 4.56's might run out of gear where a 28 wont.
Old 01-11-2004, 07:43 PM
8 Second 6 Speed Director
taner's Avatar
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
use a gear calculator to determine what will work for you best. goto prestage.com
i run 28's.
Old 01-12-2004, 09:13 AM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Here in Texas we always say bigger is better!
Go with the 28's.
Coach
Old 01-12-2004, 01:46 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,096 Likes on 720 Posts
I vote for 26's, I think 28's on a conservatively geared H/C car are overkill.
I see streetracers running 28's on the street but they need to overcompensate for racing on cold asphalt. I bet most of the 28"'d street racer guys are undergeared and don't hit low 1.5's at the track.
Old 01-12-2004, 01:51 PM
Motorboater
SilverGhost's Avatar
i can't remember if i told you this when you asked over the weekend so i'll say here.
i think you should try the 26 first, same tire i have 26X11.5X15 at a nice low PSI, you have enough suspension and the right gear to hook it at a decent track I believe.
if you spray, no way the 26 will hold, will need a bigger tire for that.
Old 01-12-2004, 02:38 PM
Silvr98z28's Avatar
I run 26" but was thinking about going to a 27". Crossing the traps at 6900.
Old 01-12-2004, 02:48 PM
CHRISPY's Avatar
I ran a 26 x 8.5 and cut 1.50 sixties.
I would go 26 x 10 inch
They will go 1.4's no problem and high 10s in a six speed HCI car with 4.10s
Old 01-12-2004, 02:57 PM
JS
JS's Avatar
Chris is right..
26/4.10 works awesome
Old 01-12-2004, 04:08 PM
Motorboater
holy crap silver98..i didnt' realize you were on a 26.
gives me some hope lol.
Old 01-12-2004, 04:13 PM
mike c.'s Avatar
will a 28in tire fit on a 01 ta with no problems?
Old 01-12-2004, 04:19 PM
LS1Tech Co-Founder
Well it depends.
A 28x9x15 ET Drag is like a narrow 27, so it fits no problem (15x8 rim).
28x10.5x15 stuff does not just go in, you end up having to clearance on the inside to make them fit.
Old 01-12-2004, 05:49 PM
Colonel's Avatar
If you can DEAD hook with a 26" slick (hey, how good is your track?) then you're better off with it, gearing issues aside. But, if ya can't hook ya can't hook.
Old 01-12-2004, 06:06 PM
Silvr98z28's Avatar
Best 60 ft on them has been 1.41 and best mph has been 125.75 I'm always very close to my 7000 rev limiter though.
