New best for my LS1 stang
Old 05-15-2010, 02:36 AM
letsrunem's Avatar
Default New best for my LS1 stang
My previous "best" was an 11.7 @ 130 on street tires spinning till the 1/8.. switched from a T56 to a TH400 w/transbrake, built 8.8, 3.73s to 2.73s, M&H slicks.. Here are the results!
http://www.youtube.com/watch?v=tyhoB_Q4WfA
Old 05-15-2010, 08:03 AM
Dickie-311's Avatar
holy ****..... was that allmotor ls1 ? ... if so my car should go really well
Old 05-15-2010, 08:35 AM
nuckifuts's Avatar
The power of the turbo
Nice runs, that is moving out for sure.
Old 05-15-2010, 10:46 AM
rotor vs. piston's Avatar
Good example that power isn't everything. Awesome run.
Old 05-15-2010, 05:47 PM
turbo_ase's Avatar
nice run... details on the engine specs and turbo
Old 05-15-2010, 11:25 PM
Monte4ever's Avatar
More please more......was that all motor or FI?
Old 05-16-2010, 03:15 AM
dimetweaker's Avatar
all motor, with bolt ons ( a TC78 turbo bolted on )
Old 05-16-2010, 08:25 PM
danbap's Avatar
how much psi was that at?
Old 05-16-2010, 08:29 PM
kmracer's Avatar
build thread?
Old 05-16-2010, 09:15 PM
reamo04's Avatar
very nice.
Old 05-17-2010, 02:02 AM
letsrunem's Avatar
347, stock crank, eagle rods, mahle pistons. I ported a set of 317s, ls6 cam, truck mani turbo setup, mbc, TC78, TH400 w/transbrake, 2.73s in the rear w/spool. This run was on 15psi!
Old 05-17-2010, 02:06 AM
Spoolinsteve's Avatar
whattttttttttttttttttttttt , congrats. I need to get mine together now!!!!
Old 05-17-2010, 03:52 AM
letsrunem's Avatar
Definitely, I'm starting on another one within the next few weeks, going to be a 6.0 with a turbo setup later on in the year.
Old 05-17-2010, 04:01 AM
BattleSausage's Avatar
Wonder were you trapping at RPM's wise through the clocks. I eventually wound up going back up to a 3.23 with my 400 and made just under 2/10 difference in my 60ft times and .38 difference on the big end.
Old 05-17-2010, 04:06 AM
letsrunem's Avatar
My converter is real loose, I think I was at 6200.
Old 05-17-2010, 10:05 AM
DiscerningZ32's Avatar
Very nice. Is that the same EVO you raced from a roll and posted in MM?
Old 05-17-2010, 11:36 AM
letsrunem's Avatar
Yes, he also raced my buddy's procharged vette:
http://www.youtube.com/watch?v=-BxwxriOrhk
