Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Anyone have oil catch can mounting pics?
Old 05-15-2010, 07:42 AM
Big Bu Bu's Avatar
Default Anyone have oil catch can mounting pics?
Looking for ideas on mounting a catch can on a V. Anyone have some pics or ideas?
Old 05-15-2010, 08:31 AM
itsslow98's Avatar
+1 been wondering the same especially since i just had a cam installed. Although the PCV system on the LS6s are a ton better then the LS1 system.
Old 05-15-2010, 08:48 AM
jerrycecco's Avatar
Here's the pic ofthe oil catch can I bought off ebay for $30 or so...
Old 05-15-2010, 09:37 AM
nikon's Avatar
^^ hows yours mounted?? Mine is just a piece of flat stock bent.
Theres a bolt that holds a bracket in the head, I just drilled the flat stock the same size and shoved it behind the bracket and tightened er back down...works like a charm.
Old 05-15-2010, 09:28 PM
lubelizard's Avatar
I installed a Mike Norris can using the included bracket onto the upper bolt associated with the tensioner pulley.
Old 05-15-2010, 11:04 PM
04CTSVMURDERED's Avatar
Here is a couple of my anodized aluminum can with braided steel lines and end pieces...
Old 05-16-2010, 08:06 AM
lubelizard's Avatar
That looks like a Mike Norris can, same as I have. I have a photo up in a few.
Old 05-16-2010, 08:19 AM
Big Bu Bu's Avatar
Looks like Mike Norris FTW.
Old 05-16-2010, 09:37 AM
lubelizard's Avatar
Photo of an installation with the Mike Norris can. I like it in that location as it keeps the wiring harness in the OEM location, and puts it in an area that does not put it in contact with anything else. I tried mounting it on the head, but it was too close to the wiring harness. Someone else mentioned mounting it on the tensioner pulley bolt, and it worked out quite well. I was able to put the OEM wire harness support back on the head, and just cleaned things up a bit with wire ties to support the wires. Where the can sits, it does not come into contact with anything. To drain it, I loosen the allen screw, lift the can up out of the bracket, and loosen the petcock at the bottom. I do it every couple to three months. There is enough capacity in the can that I can go a couple more months than that, so I may wait 5-6 months next time.
Old 05-16-2010, 09:45 AM
itsslow98's Avatar
i like lublizards and murdereds, ill have to look into that setup.
Old 02-26-2016, 11:40 AM
FBDYLVR's Avatar
I know I'm bringing this back from the dead, but thank you for posting this. I just mounted mine in this exact location.
Old 02-26-2016, 07:31 PM
tlorenzen's Avatar
Another option...How I have mine..
Old 02-26-2016, 10:02 PM
Naf
Naf's Avatar
Rx performance are the best in the market.
I have the monster can
Old 06-30-2017, 09:49 AM
AAIIIC's Avatar
Bumping an old thread. I bought a Mike Norris catch can a million years ago. I initially was going to mount it to the head, which I thought was the "normal" way to do it. However, when I mocked it up, that seemed kind of stupid, because that would make the set screw on the bracket inaccessible, so it would be a pain in the *** to get the thing positioned properly and to service the catch can. Since I didn't like that, I set the thing on a shelf, and haven't done anything with it for probably 5+ years.
I like the idea of mounting it using the tensioner mounting bolt. However, it seems like the wiring harnesses coming off the fuse box are more in the way than they are in lubelizard's pic.
I can smash the harnesses towards the fender a bit to make the catch can fit, but I'm never a fan of forcing things to fit. Have others had this same issue? Or are my wiring harnesses not routed the way they're supposed to be?
Old 06-30-2017, 10:09 AM
lubelizard's Avatar
Looking at your photo, rotate the bracket end over end. That may create room. That's how mine is mounted. The allen screw is reachable. I put some heavy duty duct tape around the circumference of the can where the screw touches the can to keep the can from slipping down. It definitely captures oil mist that would have been destined for the intake. How well compared to the RX can, I have a feeling not as well, but far better than nothing.
I suggest doing an intake cleaning using the CRC or Amsoil products. You'll be surprised how much oil residue gets caked on the intake walls and valves.
I've had to unscrew the can from the mount to reach the drain petcock, and used a small bathroom cup to catch the oil. Don't have to do it very often, but then I don't OT like you do.
I'll try to take a photo and send it to you.
Old 06-30-2017, 12:43 PM
ls1247's Avatar
Originally Posted by AAIIIC
....Have others had this same issue? Or are my wiring harnesses not routed the way they're supposed to be?
I bolted mine to the tensioner bolt and had no problems with it for a couple of years
Old 06-30-2017, 06:48 PM
Mike ctsV's Avatar
What are some good cheap ebay ones? Anyone? Ive been looking but theres so many on there and i really dont know what would work
Old 06-30-2017, 07:05 PM
FuzzyLog1c's Avatar
You sorta get what you pay for, but if you're on a tight budget, I know that Speed Engineering straight-up copied Mike Norris' catch can design and are selling it for $76.
Old 06-30-2017, 09:42 PM
SE-R Spec's Avatar
Might be able to make a real cheap one out of a sealed unit (air compressor components come to mind) with one line going in the top from the valve cover and one line going out the side to the TB... Oil is heavier than air and MOST will drop into your container.
Just make sure it is sealed or unmetered air will enter the engine after the MAF and cause problems
Old 07-02-2017, 01:27 PM
heavymetals's Avatar
Here is where I mounted mine:
Quick Reply: Anyone have oil catch can mounting pics?
