engine mounts
I used stock SB frame stands, and 1" setback plates on my install. Edelbrock headers fit well, but had to modify 1 tube for clearence to mechanical clutch linkage.
the 1" setback plate put the bellhousing in the same spot as the original SB, so driveshaft length, and trans position, will be the same.
Barrett
Barrett
